Is it possible to add support to run HouseBot as a Windows service. It would be great to be able to be able to have housebot running in the background without having to log into my main server computer.
Jesse
HouseBot as Windows service
I installed firedaemon and was able to get HouseBot to run as a service. I only had a script running that would beep every second so I knew it was alive, so it's hardly a conclusive test. However it is promising and a simple way to get it to work.drewkeller wrote:i tried running it as a service with firedaemon (firedaemon.com) and it didn't seem to work, not sure why. is there a simple fix for that?
In my configuration I hade to check the 'Interact with Desktop' check box in FireDaemon. I could use a login and it would work, but you could not actually see the app, which makes it hard to configure.
What problems were you seeing when trying to use firedaemon?
the problem was, it didn't seem to be running my scheduled tasks
i'll try the "interact with desktop" option
thanks.
P.S.
yep, it looks like that will work.
i noticed that restarting the service while logged on displays the tray icon, so maybe add a task that restarts the service at the first logon? how would i do that with HB? also, is there a way to perform something at system startup, before log on? i couldn't find anything about it.
thanks.
P.S.
I don't understand exactly what you are wanting to do. You can set the startup mode for the service to be 'Automatic' so it will start when the system starts (before anyone logs on).drewkeller wrote:i noticed that restarting the service while logged on displays the tray icon, so maybe add a task that restarts the service at the first logon? how would i do that with HB? also, is there a way to perform something at system startup, before log on? i couldn't find anything about it.
