I had a couple ideas which I thought would be useful:
1. I use a program on my HTPC that launches various apps. I have similar behaviors done via housebot so that I can use my IR remote to do the same things. It would be nice if I could change a property externally which would force housebot to run some the same tasks. Maybe something like "housebot.exe -propertychange <property name> <property value>"?
2. Ocelot IR recognitions is generally slow. Since housebot has a list of the various IR command to recognize, it could tweak the max ir register to the absolute minimum needed to increase recognition speed.
External property changes & ocelot speed
Re: External property changes & ocelot speed
jw666,
I made an "External Control" Device that you can use to control HouseBot remotely. It contains a new application (HB_Control.exe) that you can use to do some simple control of HouseBot. Mainly if you can set Property values and start Tasks, that's about all the control you need.
Check it out and see if it works for you. You can find it in the Plugins section of the Download page.
jw666 wrote:1. I use a program on my HTPC that launches various apps. I have similar behaviors done via housebot so that I can use my IR remote to do the same things. It would be nice if I could change a property externally which would force housebot to run some the same tasks. Maybe something like "housebot.exe -propertychange <property name> <property value>"?
