When editing a theme, HouseBot suddenly quits, throwing the following to the dump file:
====== Begin Dump - Wednesday, August 25, 2004 18:54:46 ======
Server Version = 2.20
Thread Type = Main UI Thread
Thread ID = D74
Fault address: 0047534A 01:0007434A C:\Program Files\HouseBot\HouseBotServer.exe
Registers:
EAX:FFFFFFFF
EBX:00000000
ECX:0856F3C8
EDX:08557D64
ESI:084B0AA8
EDI:00000000
CS:EIP:001B:0047534A
SS:ESP:0023:0012D24C EBP:00000000
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010286
Call stack:
Address Frame
====== End Dump ======
I should add that I use a backup of HBData.mdb from HouseBot version 2.10 (I experienced other problems and decided to go back). Note that the current HB server version is 2.20.
Any suggestions (Scott?)
Yoram
Problems while editing a theme
- HouseBot Special Member
- Contact:
I'm quite sure that the last action was to delete several controls, including an image control.
In another occation (just a little later) HB also quited, with a slightly different dump code:
====== Begin Dump - Wednesday, August 25, 2004 19:32:10 ======
Thread ID = FE4
Registers:
EAX:00000019
EBX:00000000
ECX:085967F0
EDX:000001E2
ESI:00F35320
EDI:00000000
SS:ESP:0023:0012D24C EBP:00000002
Flags:00010202
Call stack:
Address Frame
0047534A 00000002 CxImage::`copy constructor closure'+738DA
Yoram
Thread ID = FE4
Registers:
EAX:00000019
EBX:00000000
ECX:085967F0
EDX:000001E2
ESI:00F35320
EDI:00000000
Flags:00010202
Call stack:
Address Frame
Yoram
