After installation, the housebot program starts, but i get a message "ip server failed"
What's this"?
Housebot initialization problem
I saw this same error when I had the Application Layer Gateway Service running. After I disabled the service (I didn't need it), HouseBot started without the error.
If you want to change the port that HouseBot uses for Software Remote connections, search for Software Remote Connection Port in the HouseBot online help. it will give you the step-by-step. Be sure to change it on each Software Remote machine also.
