I just downloaded Meedio Housebot and have been tinkering with it for a while.. What are the requirements for using a PocketPC as a remote. Does it have to have a Wifi card or can it use bluetooth, or even IR??
Thanks!
Using a Pocket PC as a remote
- HouseBot Special Member
- Contact:
Bluetooth will also work, but it is not as good as WiFi.
Although the receive range that I experienced was very similar to the WiFi's, I encountered an annoying issue with bluetooth: I had to manually establish the connection between the PocketPC and the server every time the PocketPC was turned on. With WiFi, the connection is established automatically.
Yoram
Yoram
yaccri wrote:Bluetooth will also work, but it is not as good as WiFi.
Yoram
Ok Thanks.. WIlling to give it a shot now..
Ahanix D5 Media Center Case // AMD Athlon XP 3000+ // MSI K7N2 Delta2-LSR Motherboard // 512MB PC3200 Memory // ATI 9600 Pro // 120 GB, 80 GB 160 GB HDD's //
