When using Focus Control Management on a software remote, is it possible to change the colour of the rectangle that surrounds the buttons?
I have a soft remote that is run over composite video to an LCD and the contrast between the yellow and the background make it a bit tricky to see until it moves.
James
Focus control Mnagement
There is a way to change the color, but it requires running RegEdit on the Software Remote machine to configure it. If you're comfortable with using RegEdit:
- Go to the HKEY_LOCAL_MACHINE\SOFTWARE\Meedio\HouseClient\Configuration Settings key
- Add a new DWORD value named Control Focus Color
- Set the new color by using an RGB color pattern of BGR. For example to set it to blue, the value would be ff0000. Purple would be ff00ff.
