I have set up HouseBot on my laptop. I currently have everything setup and functional. I want to set up the exact same configuration on another laptop. I want to keep the themes, customized buttons, learned IR codes, devices, hardware interfaces, remotes, etc.
I know that there is a way to import a theme. Is there a way to export everything and then import it onto another PC?
Assuming you install everything using the same directory names, you should be able to simply copy the entire '\HouseBot\Config' Directory (and all directories under it) to the new machine.
