I have got learning IR code of my VCR remote. play, pause, stop, etc.
When i test code in USB UIRT Configuration windows, the device (USB IURT) send IR command to my VCR (for example): good . But, when i APPLY the IR Code in Remote Control Library : nothing . :shock:
What exactly do you mean by "nothing"? All applying really does is to assign the IR code to a particular property value. After it has been assigned to a value, try changing the property to that particular value and it should send the IR code.
