Are there any plugins/devices for getting windows information displayed in a software remote.ie disk drive space,free memory etc.or even uptime of Housebot server?
System Info
System Info
Regards
PT
PT
Scott, don't play with this because I just finished it.
It displays Disk drive info, Memory, PC and HB uptimes and even IP and hostname info in a single log view.
I will e-mail it to you because I really don't know how to attach in this forum. Hope it makes sense and maybe you could make it more general so others can use it.
Richard
Richard
You can put attachments in the Extensions forum. That is where I have posted stuff that I have done in the past.
Scott J
aka spike5884
Scott J
aka spike5884
The Windows Info script is about to be released.
I also wrote an EMail module (vbscript). It runs on a (two) minute timer and checks up to 4 different pop3 accounts. Info about the sender, subject, attachments etc is displayed in an alpha list view. An email can be selected in this list view and the content of the email can then be displayed in another alpha list view. The module does not delete the emails on the server although it is very easy to set this differently and emails can be deleted by selecting them in the list view and pressing the Delete button. If a NEW email is received, a popup panel is displayed for a certain amount of seconds. An extra popup panel is used to set all of the account info such as: account name, server name, user name and a scrambled password. The amount of popup seconds can be set there as well. This script is dependant on a third party freeware dll which provides the pop3 objects that are called for from the script.
If anybody is interested, please let me know and I can see if I can make this script more generic and create an export for it. It contains many different properties for all of the account info.
Richard PC Info script
I've packaged Richards PC Info script into a HouseBot export file that you can simply drag and drop onto HouseBot (and then restart) to use.
This import will
(1)Create a Device (PC Info) and associated VB Script.
(2) Create a Sleep Timer Device and Task to periodically to execute the script. You can adjust the rate at which the PC Info Device will run by setting the timer value.
(3) Create a Startup task to set the HouseBot startup time.
Since the Device is done with VBScript it should be fairly easy for others to add their specific system info needs to the script/Device.
If you want to display the Log PC Info property of the PC Info device in a Theme, using a List control will display the format better, since the data is tab formatted.
Thanks Richard for your contribution!
This import will
- pc_info.hbx
- (2.58 KiB) Downloaded 417 times
Minor change to the script. The Script Device to set the startup time isn't needed, since it can be done more simply right from the Startup script (Thanks to Richard for pointing out what you think I would have known )
FYI: Also, it creates a startuP Task now. Notice the upper case P. In HouseBot you can have multiple startup tasks by using different case combinations of the name STARTUP.
I've updated the attachment in the previous message with the new export. If you don't see the attachment, make sure you are logged in to the forum.
- HouseBot Special Member
FYI - the task that gets created is named staruP but it should be startuP (the second "t" is missing). Also it appears there should be another task to periodically run the "PC Info" script so that the date is kept up-to-date.
Also on my system the host name and IP address didn't get populated. I'm going to do some more testing and I'll pass on whatever I find.
The reason that my IP address didn't get populated is because as written the script only updates the IP address and host name fields every 10 minutes "on the fives". This means that even if you run this task on startup the value will only be populated if the time is "right".
Also the IP address being shown is our public firewall address instead of my DHCP client address (I'm testing this at work over lunch) and the host name is still not being populated. I'm going to do a bit more research on the network code and see what I can come up with. Other than these minor issues though this is a really nice script. Thanks Richard/Scott!
Dave,
I set this IP update rate each time the script ran, but then after some hours I got an error. Then I went to the IP site and it said that my daily 300 times had expired. So running this script every minute gets me about 5 hours of IP info. I had to get this rate down a bit and introduced the 10 minute timer. There are lots of other ways to come about this. Also that 10 minute timer is the reason why i have to populate a separate IP and host name property to overcome the other 9 minutes. Hopefully others now come up with more additional stuff to make it even better...
Dave
If you want to see the ip address of your local system. Then you can use part of the following script. I have been playing with these wmi scripts and missed something very obvious which Richard helped me with to get it into Housebot. You can query most of win32 items with these type of scripts.
Obviously change the Set Device property to whatever you need. I have left the others in if anyone wants to see the type of info available.
By the way Bob is on my test machine easy device name!
' IP Address
Dim strComputer, CRLF
Dim colDrives, strMsg
Dim WSHNetwork
strComputer = "."
CRLF = Chr(13) & Chr(10)
Set objWMIService = GetObject ("winmgmts:" & "!\\" & strComputer & "\root\cimv2")
Set colAdapters = objWMIService.ExecQuery ("Select * from Win32_NetworkAdapterConfiguration Where IPEnabled = True")
For Each objAdapter in colAdapters
A=strdsk&"Host name: " & "=" & objAdapter.DNSHostName & CRLF & _
"IP address: " & "=" & objAdapter.IPAddress(i) & CRLF & _
"Description: " & "=" & objAdapter.Description & CRLF & _
"Physical address: " & "=" & objAdapter.MACAddress & CRLF & _
"DHCP enabled: " & "=" & objAdapter.DHCPEnabled
Next
SetPropertyValue "bob.Listing",(a)
'Memory etc
Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" _
Set colComputer = objWMIService.ExecQuery ("Select * from Win32_ComputerSystem")
For Each objComputer in colComputer
intRamMB = int((objComputer.TotalPhysicalMemory) /1048576)+1
SetPropertyValue "bob.memory", "System Name: " & objComputer.Name & vbCr & "Total RAM: " & intRamMB & " Mb"
SetPropertyValue "bob.Loggedon",objComputer.UserName & " is/are logged on"
SetPropertyValue "bob.SystemType",objComputer.SystemType
Next
'Operating system
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colOperatingSystems = objWMIService.ExecQuery _
("Select * from Win32_OperatingSystem")
For Each objOperatingSystem in colOperatingSystems
SetPropertyValue "bob.list", objOperatingSystem.Caption & " " & _
objOperatingSystem.Version
Next
' IP Address
Dim WSHNetwork
strComputer = "."
Next
'Memory etc
Next
'Operating system
Next
Regards
PT
PT
Amazing what a difference a little 't' can have! Ok, I've updated the export once again with the correct Task name. Needless to say, I'm not testing this stuff very well, so hopefully it will work better. I've also added a Task and Sleep timer to execute it every hour. I also removed the limit in the VB Script so it will get the IP every time it runs (although I only have it set to run every hour).dlmorgan999 wrote:FYI - the task that gets created is named staruP but it should be startuP (the second "t" is missing).
