Hello,
I search 1-wire / ibouton (http://www.maxim-ic.com/1-Wire.cfm) plugin for housebot ( existe for homeseer)
1-wire / ibouton
I have tried some differetnt wariants to get 1-wire data in to HouseBot.
(mainly temp but also a weatherstation) I have also looked for a way to plot temps in housebot... recently i came across this http://www.mrsoft.fi/software.htm (LogTemp). it makes pictures and logfiles wich can be presented in dynamic pictures in housebot. it makes CSV and XML logfiles wich probably easy can be parsed and inputed in Housebot thru a script.. (need some help with this :) ) I have just tested it and it looks like this will do the job. Using 1-wire for output and critical input (motion detectors etc.) is not reliable enough but for weather data and temperatures its ok..
would really like to see a device/interface solution to 1-wire
regs
regs
