I would like to have a property change button on a theme that would change one property value to a value which is based on another property value.
I tried to put in the new property value something like:
%%My Dimmer.Reported State%%+5
It seems like HB ignores the calculation.
I should note that both properties are defined as alpha-numeric.
Is there a way to tell HB to calculate the new property value?
Calculations with substitution strings
- HouseBot Special Member
- Contact:
I want to keep things simple.
I also want to use the 'repeat' function of the dimmer.
I can write only one script to handle all the dimmers, using a null device that will pass parameters to the script. However, other issues like being able to 'repeat' an action and to control more than one dimmer at the same time from different SWRemotes will come up.
If possible. I prefer to directly change the property.
It's a good idea, but won't work currently. In Tasks, there's a little logic for using + or - when comparing times, but nothing for any of the other property values. It would make sense to do it for numeric property types.
Alpha numeric.... well that could be done too. Actually, if you use < or > for alpha numeric properties now, it assumes them to be numeric. I could probably do something similar.
I'll add it to the V3 list.
