Calculator
Calculator
Just wrote a simple calculator script + panel.
It works.
The hbx file contains the panel, script, script device and null device.
Have fun.
Updated 5 August 2007
It works.
Have fun.
- Calculator.zip
- (1.2 KiB) Downloaded 2187 times
- Calculator.JPG (17.97 KiB) Viewed 25157 times
- Calculator.hbx
- (44.6 KiB) Downloaded 2193 times
Last edited by Richard Naninck on Sun Sep 23, 2007 4:25 pm, edited 5 times in total.
Just updated the first post with the latest version. This one has memory functions (M+, MR, MC) just like the standard windows calculator. Changed the image as well as the hbx file. Not sure what the windows MS button stands for, so I left it out.
If this product (plugin) is of interest to anybody and they want to have more functions like 1/x, %, sqrt etc please let me know and maybe I will add those too. It's just that I usually don't use these functions so I left them out.
- HouseBot Special Member
Aha, that figures and it makes so much sense that I will have to add it.
I always use M+, but I always start from 0. While Starting from 0, M+ and MS do the same thing.
Yesterday I found three small bugs.
- Couldn't enter 0.x and now that is fixed, but not uploaded yet. Will do so with the next version containing MS.
- Couldn't do Value + Memory whereas Memory + Value was possible. The next version both are possible.
- After storing a value in Memory and then entering a (new) digit, the digit was added in the display whereas it should start from zero again. Also fixed.
Also added Clear^Exit for the Panels Exit List. This clears the buffer and the Memory after Panel Exit so the next start will always be clean.
I have packaged Richard's awesome Calculator with an additional theme.
- Calculator.hbx
- (151.52 KiB) Downloaded 2196 times
- calculator.jpg (45.92 KiB) Viewed 25142 times
A suggestion for your calculator script: On many calculators, entry of a number, the times (X) sign, then =, squares the number. That is: 5X= yields 25. On yours, it yields 0, since there is no 2nd number. Also, a percent function would be nice. Just a thought I had using it the other day...
FWIW,
FWIW,
I tried a simple hack to get the X = square in, but it wasn't so easy because the function messed with other calculations. I will look into this next week orso. As for the %, I never understood it's functionality so unless I get that straight, it probably won't make it in. Luckily this is all opensource so everybody is free to make their own adjustsments.
1/x and sqrt actually do make sense.
