THC Jukebox - Keyboard script
Incoronado, should the keyboard script be running all the time, like the Jukebox script? I cannot get mine to manually start, so the keyboard panel opens but there is no way to close it (with the ESC key) since the script is not running. And I don't see anything that starts it. (I'm just now getting to the playlist options in THC. I need to "shrink" the keyboard so it will fit in 800x600. )
No. I use a task that triggers the keyboard script on Keyboard.Keyboard Key Not Equal to '#$R' (or some value it will never be). The keyboard panel is designed so the Enter key should close the panel. At this point the Keyboard buffer will contain whatever you typed previous the selecting the enter key (or closing the panel.) The THC Jukebox.hbx contains an example with a working keyboard.
Attached is a zip file containing the elements of my shrunken (to 800x600) keyboard for Incoronado's terrific THC Jukebox. Basically, it includes the background and the various sized keys needed to fill it out. Placement goes fairly fast but tediously. Don't forget the labels (unchanged from the large version). I copied and placed those from the large to the small background then shrunk their width.
I can upload my smaller (800x600) main page but its likely you'll want to customize your own to add/remove elements to fit the smaller real estate.
- keyboard_800x600.zip
- 800x600 keyboard elements for THC Jukebox
- (92.39 KiB) Downloaded 1989 times
Most of my main page was left intact except for the album cover art. I moved that to another page that opens 1 minute after the play button is pushed. That page also has volume up/down, mute, and progress bar. Another page I added includes EQ sliders, volume and mute. I also scrunched down the list boxes on the main page and reduced the font sizes.
markd,
Below is a one panel theme import file that should contain the 800x600 keyboard background, key image files, and a keyboard device. The file is zipped; you'll need to extract it to create an hbx first. This is my first export so I'm not guaranteeing success. Let me know if you encounter problems.
- keyboard_small.zip
- (97 KiB) Downloaded 2004 times
