Error reading COM port. Error = Insufficient data in read buffer
i keep get this error message when i try and run a task.
i am using a CM11a interface( USB ) and a X-10 lamp module and it will not turn the lamp on can any one help with is problem , i think it may be a problem with the USB connection but the system works if i use activehome software ?
I think the cm11 supported by housebot is the serial version not the usb version. You can use the serial one or the Powerlinc USB version from Smarthome
