Text to speech?
Text to speech?
Post by markd »
I'm not having much luck locating the MS SAPI files for text to speech- can anyone help?
Also, I have multiple sound cards in my system- is there any way to direct the speech to a particular set of outputs?
thanks
Markd
wetwired
Re: Text to speech?
Post by wetwired »
Re: Text to speech?
Post by markd »
Yes! Thanks! MS website is full of broken links.
Scott, any input on how to direct to a particular sound card output?
Re: Text to speech?
SAPI seems to support that, but it's not implemented in the plugin. Right now it just outputs to the default audio device.
Re: Text to speech?
Post by markd »
Would it be hard to change it?
I'm going to try using this-
http://www.toflo.de/Downloads/Tools/Sou ... x.html#CMD
but there seem to be some restrictions, not sure it will work.
thanks
Markd
Re: Text to speech?
markd wrote:Would it be hard to change it?
Probably not, but I can't say for sure. I'll take a look at it soon and let you know.
bryan
Re: Text to speech?
Post by bryan »
I was wondering about something like this as well. I'd like to be able to output speech/voice to one sound card and music, via HB/winamp, to another (probably the default). The goal I have is to establish a management channel with strategically located speakers, separate from home entertainment (where volumes get adjusted, amps turned off, etc).
Re: Text to speech?
Bryan,
I have an experimental version that markd is testing now. If you want to play with it, just let me know.
