Double Precision Numbers and Task Evaluation
Scott:
Can tasks evaluate a double precision number? I have a property value (alphnum) set by a script where the variable in the script is double precision. If I use a task to evaluate if the value is greater than, say 0.250, the task never executes even if the value is above this number. Should I mutliply these numbers by 100 and convert them to integers prior to populating a property in HB? I have to use double precision to arrive at the number because it is calculated from other similarly small values.
Re: Double Precision Numbers and Task Evaluation
Alphanumeric properties are cast to integers when comparing, so you will lose the decimal during the test. If you use a numeric property value, it should work.
