Harhware interface Global cache
Is there way of automatically starting the hardware interface status to enabled when Housebot is restarted using a batch file. I have a start up task but cannot seem to see a way of changing this property
Regards
PT
PT
Re: Harhware interface Global cache
PT:
It's been a while...
No, there is no way to do this. However, if the hardware interface was enabled at shut-down, HouseBot will attempt to reconnect to the interface at start-up. There were some issues with prior versions of HB losing connection to the GC devices; however, I believe Scott has beefed up the connection/reconnection code in the latest version. If you are having some connection issues, move up to the latest version and see if it doesn't fix your problem.
Thanks Osler for the reply. I was doing some housekeeping and thought I would add the global cache device to the start up task then noticed I could not do this, hence the question
Regards
PT
PT
