Z-wave Motion Sensor & Multilevel senor not supported ?
parshva
Post by parshva »
Hi Scott,
I tried installing the Z-Wave sensor device from Homeseer HSM-100 but it does not show the correct properties. Only the Level property has some numeric value from the device. The scale & type property shows this status ' Dimensionless value'. Additonally, the Door/Window Sensor from Aeon Labs always has its state to Off. I did try both these devices to perform a light on action when motion is detected directly with the z-wave binary switch device and it works like a charm..but they don't work correctly with the Housebot software.Can you please suggest any alternatives to add the required property ?
-Parshva
Re: Z-wave Motion Sensor & Multilevel senor not supported ?
It sounds like the current version of the HSM-100 firmware is no longer compatible with the HouseBot Z-Wave sensor.
parshva
Post by parshva »
Hi Scott,
Your software is really cool & user friendly. Will you be adding support for these sensors anytime soon? Any release dates for these? Any workarounds to make them work as of now?
-Parshva
Parshva,
Sorry to say that there are no plans to add support for this in the foreseeable future.
chrisrey
Post by chrisrey »
There is no plan for the future with housebot! It sounds like housebot is dead.
Not dead. Just resting.
chrisrey
Post by chrisrey »
definitively hope so ;o) a roadmap could be appreciated!
