Hi Scott,
I'm willing to help out in any way I can.
I don't think the Windows Message Device will work. Besides, there is a bug inherent in the MultiView software and I have spoken to and confirmed this with Tech Support. It offsets the X10 command recieved but not always by the same offset. Sometimes it's by, 1, other times it's 2 or 3, then back to 1.....It's a real pain. They are supposed to fix it but ....Besides it has no streaming or remote capabilities at all anyways. It just takes snapshots. Really kinda a useless piece of software. So lets forget about MultiView. I just thought maybe the virtual Pan-n-Tilt remote that it comes with might help out somehow to encorporate support for the CM19A and hence for PAN-N-TILT
If you think the software will help you, I can send you MultiView and my registration code (actually it's just a 100KB installer, and it downloads the rest of what it needs through the Internet, and then registers through the Internet as well).
As far as specs for the CM19A, is there anything I can do to obtain them from the device? Like an RF frequency reader or something, to read what it puts out for PanUp, PanDown, etc...? I imagine if those commands can be reproduced, they should pan and tilt the cameras just fine.
OR, I am willing to send you a CR14A PAN-N-TILT remote with all the PAN/TILT buttons on it, if you think you can do something with that. I imagine the CM19A would have to be reproducing the RF commands that the actual remote itself is putting out. Or what about the drivers for the CM19A? Would those help you in any way? I believe they get installed with the MultiView software.
For the streaming stuff, I understand as long as the capture device is connected to the PC, you should be able to grab the input from the device, and pump it into an installed CODEC for compression, and then serve it out (or push it out upon request) on a port. Like Windows Media Encoder (good product to look at, but it encodes to Windows Media Video (WMV) only. But of course, right? Microsoft-to-Microsoft
). Actually this is what I use for now. I start WME in the morning to capture input from the VA11A USB vid capture device, encode it to WMV medium quality or so, and then serve it out on a port. I then connect to WME with Windows Media player (http://<ip_address>:<port_no>) and can see the stream from the current camera. I then use HouseBot remote to swith my cameras.
In all my hunting around for good software, I came across "All House Access" (
http://www.allhouseaccess.com) which does video streaming through its web interface (about a frame per second or so), and the web/streaming server is built into the software. It has a 14 day trial period. It's not nearly as powerful and flexible as HouseBot and they want around $150 US for it !!! I think NOT !! But I tried it out for a couple of weeks. Maybe you might want to look at it.
I can email you the installer and the reg codes, and send you the CR14A remote if you think you can use them somehow.
Let me know how I can help out in any way at all with these feature developments. I will do it if I can.
- John
