Alphalist title doesn't change
Howto:
Enter the theme editor and try to change the title bar name of an existing aplhalist. It won't change but if the theme is saved and recalled in the theme editor, the name has changed.
It occured to me when adding an extra alphalist by copying an existing alphalist and changing the name. The teme editor kept on showing the name of the copied alphalist even though the name was changed in the list properties.
See the attached image where the Title "Garage Log" has been changed into "Should have changed;)" but it doesn't show...
