It's a simple device. Source code included below. If you alter the code and recompile please generate a new Guid for the COM and class interfaces in the attribute decorations:
Imports System.Net
Imports System.Text
Imports System.Web
Imports System.IO
Imports System.Runtime.InteropServices
Namespace Prowl
<ComVisible(True)> _
<Guid("0F7D00C3-CF88-4D4A-AA6F-72866C432D78"), _
InterfaceType(ComInterfaceType.InterfaceIsIDispatch)> _
Public Interface IProwlMessenger
Property APIKey As String
Property NotificationURL As String
Property NotificationApplication As String
Property NotificationEvent As String
Property NotificationDescription As String
Property ProviderKey As String
Property Priority As Integer
Function SendNotification() As String
End Interface
<Guid("7E0547BE-6C28-4DDA-AD8F-3A2BD5394F31"), _
ClassInterface(ClassInterfaceType.None), _
ProgId("Prowl.Messenger")>
Public Class Messenger
Implements IProwlMessenger
Dim _apiKey As String = ""
Dim _url As String = ""
Dim _application As String = ""
Dim _event As String = ""
Dim _description As String = ""
Dim _providerKey As String = ""
Dim _priority As Integer = 0
Dim _timeFormat As String = "MM-dd-yyyy HH:mm:ss"
Public Sub New()
MyBase.New()
End Sub
Public Function SendNotification() As String Implements IProwlMessenger.SendNotification
If _apiKey = "" Or _event = "" Or _description = "" Or _application = "" Then
Return "The apikey, event, description, and application need to be set prior to sending notification."
Exit Function
Else
Dim prowlAddress As Uri
Dim request As HttpWebRequest
Dim response As HttpWebResponse = Nothing
Dim data As StringBuilder
Dim byteData() As Byte
Dim postStream As Stream = Nothing
'Dim reader As StreamReader
prowlAddress = New Uri("https://api.prowlapp.com/publicapi/add")
request = DirectCast(WebRequest.Create(prowlAddress), HttpWebRequest)
request.Method = "POST"
request.ContentType = "application/x-www-form-urlencoded"
data = New StringBuilder
data.Append("apikey=" & System.Uri.EscapeDataString(_apiKey))
data.Append("&providerkey=" & System.Uri.EscapeDataString(_providerKey))
data.Append("&priority=" & System.Uri.EscapeDataString(_priority.ToString))
data.Append("&application=" & System.Uri.EscapeDataString(_application))
data.Append("&event=" & System.Uri.EscapeDataString(_event))
data.Append("&description=" & System.Uri.EscapeDataString(_description))
byteData = UTF8Encoding.UTF8.GetBytes(data.ToString)
request.ContentLength = byteData.Length
Try
postStream = request.GetRequestStream()
postStream.Write(byteData, 0, byteData.Length)
Catch wex As WebException
Return wex.Message.ToString
Finally
If Not postStream Is Nothing Then postStream.Close()
End Try
Try
response = DirectCast(request.GetResponse(), HttpWebResponse)
Return response.StatusCode.ToString
Finally
If Not response Is Nothing Then response.Close()
End Try
response = Nothing
postStream = Nothing
request = Nothing
byteData = Nothing
data = Nothing
End Function
#Region "Public Properties"
Public Property Priority() As Integer Implements IProwlMessenger.Priority
Get
Return _priority
End Get
Set(value As Integer)
_priority = value
If _priority < -2 Then _priority = -2
If _priority > 2 Then _priority = 2
End Set
End Property
Public Property APIKey() As String Implements IProwlMessenger.APIKey
Get
Return _apiKey
End Get
Set(value As String)
_apiKey = value
End Set
End Property
Public Property NotificationEvent() As String Implements IProwlMessenger.NotificationEvent
Get
Return _event
End Get
_event = Left(value, 1024)
End Set
End Property
Public Property NotificationURL() As String Implements IProwlMessenger.NotificationURL
Get
Return _url
End Get
_url = Left(value, 512)
End Set
End Property
Public Property NotificationApplication() As String Implements IProwlMessenger.NotificationApplication
Get
Return _application
End Get
_application = Left(value, 256)
End Set
End Property
Public Property NotificationDescription() As String Implements IProwlMessenger.NotificationDescription
Get
Return _description
End Get
_description = Left(value & " " & Now.ToString(_timeFormat), 10000)
End Set
End Property
Public Property ProviderKey() As String Implements IProwlMessenger.ProviderKey
Get
Return _providerKey
End Get
_providerKey = Left(value, 40)
End Set
End Property
#End Region
End Class
End Namespace
