Clean Install
jacco van der Ven
Clean Install
Post by jacco van der Ven »
I did a clean install, but I can't select the hardware device MQTT ?
How can I activate it?
Re: Clean Install
Are you seeing any errors in the error log when starting HouseBot?
Re: Clean Install
And what version of Windows are you installing on?
jacco van der Ven
Re: Clean Install
It is on Windows XP☹️
Also the latest version of housebot.
Housebot is running fine without errors, but there was no option for the MQTT device, i don’t know if there missing more devixe’s.
Housebot was installed before on this pc and this version of windows.
Re: Clean Install
MQTT doesn't get installed with the 'typical' setup. If you don't see MQTT as an option in setup to select, it is because MQTT requires Windows Vista or newer (probably why you're not seeing it on XP).
