Meedio HouseBot Connector Feedback
Hi Heff,
These are the very first functions I set up and it's quite easy to do.
1. Create five property change buttons on a HouseBot theme panel
2. Use the Meedio Connector device you created for the device name
3. Use the "Command to Send" property on each button
4. Set the values to LEFT, RIGHT, UP, DOWN, SELECT
loo_hoo_ser
Executing Meedio Modules directly
Post by loo_hoo_ser »
How would I go about having Housebot execute Meedio modules directly, or rather, the menu items I have in Meedio Essentials?
For example, I have a program module that invokes TheaterTek with certain command line options from a Meedio menu. How would I get the Housebot connector execute this menu item directly as if I were selecting it from Meedio Essentials itself?
Thanks.
acheslow
Post by acheslow »
To answer Heff and loo_hoo_ser -
You can set a jump target name for any module in the Meedio Essentials configuration tool and then in Meedio HouseBot set the value of the "Message to Send" property of the Meedio Connector device to:
system.jump target=jumpname
where jumpname is the name of the target defined in Meedio Essentials.
loo_hoo_ser
Hi again,
Building onto the last post that I wrote,
I am having problems with my Housebot talk to the Meedio connector on my Meedio setup.
I do have HB 2.22 and Meedio Essentials 1.33 and followed everything in the README.TXt that came with the Housebot connector package.
I created a software device in Housebot and named it to match the name of the instance in Meedio Essentials Housebot plug in. It appears that if you don't name the software device in HB with the same name as the Housebot plugin in Meedio Essientals, Housebot can't see it (there is no place to enter a specific IP address so I am surmising that it gets that information from the instance name when Meedio Essientials hooks up with HB).
Anyway... From Housebot, I am successfully able to send COMMANDS to Meedio Essentials (e.g. LEFT, RIGHT, UP, DOWN, SELECT) when I enter a command in the property value field. However, when I try to send a MESSAGE, Housebot promptly crashes! Just plain exits - no error messages of any sort!
What am I doing wrong here? Also, it appears that a MESSAGE is what I need to send to Meedio Essentials in the form of "system.jump <target>" where <target> is the jump target name of the menu item I wish to execute.
Can anyone help me figure out why I can send commands to my Meedio Essentials, but not messages that appear to cause my instance of Housebot to crash??
Thanks.
loo_hoo_ser
Alan,
It appears you wrote your reply while I was writing my above post. It appears I was on the right track, but I forgot to include the "=" - I was entering system.jump <target name>" without the equal sign.
I modified the message to the correct format that you posted (including the equal sign). However, that did not work. My Housebot instance still crashes and burn by exiting promptly when attempting to send a message to Meedio Essentials. It appears sending any message causes my HB to crash/exit.
edit - was incorrect in my original response
loo_hoo_ser
Sorry to write so many posts - it looks as if I'm talking to myself!
I've had some success in getting what I wanted - by sending a COMMAND, I can jump to specific target by sending the name of the jump target itself.
First, you have to configure it as a command in the input tab of Meedio and adding the name of the desired jump target of the module to invoke. This will make it available as a command to HB.
However, I'm still bothered that I can't send messages to Meedio because that locks me out of many capabilities of Meedio from HB.
Thanks...
davidne0uk
Post by davidne0uk »
I am also seeing the same issue as BigBen, unable to change the value of any device property that has a numeric value, e.g Leviton Dim Level, Thermostat Set point, etc. I can see the value in Meedio, but it can't be changed.
Is there anyway of getting the values of the properties into the library so I can use them on datafeeds?
Davie
ozhtpc
Finally working
Post by ozhtpc »
Thanks for the pre-release plug-in. I have now successfully configured Meedio to control my Home Theatre. I can now start a movie using a preset for the theatre environment that does the following with one Meedio control
Lower Screen
Dim Ceiling lights
Turn on Rope Lights
Turn on seat lighting
Turn on Exit lights
Turn on On-Air lights
Turn Powered Sub-Woofer On
Turn Exhaust Fan on
I created a null devive in Housebot to so this and set up a task based on the value of the property fo that null device. eg "StartMovie=Start" or "StartMove=Stop".
By changing the property value to Stop the inverse of the above happens.
I also have individual controls for each device.
I now startup Housebot, then Meedio in myHTPC Startup and now control TV, Radio, CD Player, DVD Player, Divx Movies, Internet Weather and Home Automation with a Streamzap remote.
Now I can hand it over to the wife and kids.
My next experiment is to embed the housebot movie start/stop tasks in to the Meedio Essentials Movie Play and Stop buttons.
Davieboy
command/message list
Post by Davieboy »
Has anybody got a list of commands/messages that meedio can respond to from the housebot plugin? I have found a basic list in the input menu on the configuration tool for Meedio. I am looking for some more advanced control like change aspect ratio etc. Also if anybody knows where i might find some nice icons for remote skins that would be great. Thanks guys
Pinkie2
Post by Pinkie2 »
Pentium 4 2,4, Thermalright XP-90/Papst 3412/2L
MSI RX9550SE-TD128, Wint-TV pvr 350
FSC D1683A, 512 MB DDR
Samsung SV0802N, NEC ND3520A
NB-Fortron UltraSilent 300 Watt
ATCS-620, Papst 4412/F2GLL
IPaq rx3715 (Netremote)
Win XP SP2, TVC 1.4
Davieboy
Post by Davieboy »
thanks for the links pinkie2
Pinkie2
Post by Pinkie2 »
Can Pda-softwareremote react on messages send by meedio???
Win XP SP2, TVC 1.4
ozhtpc
Housebot Plugin unstable
Post by ozhtpc »
I have looked back at previous forum messages and found an old Meedio problem now re-occurring as a result of using the Housebot Plug-in. Whilst the housebot plugin is enabled I am not able to play movies from disk, It will start playing a movie that was not already partly played and then freeze all control of Meedio (but still keeps playing the movie). If a movie was to be resumed, then it would not do anything and then freeze.
My only option is to disable the plugin until this can be solved.
I have also noticed that Meedio now takes about 30 seconds to load (plugins) Again the housebot plugin is the culprit as it loads instantly when it is disabled.
Pinkie2
Post by Pinkie2 »
do you have any idea how I can change panles from Essentials on my SoftwareRemote?
So that a pop-up on my SR says who's calling me or that the "dvd-control-panel" is shown, when I insert a dvd in my HTPC?
Or is tgere a possibility to start a *.exe (e.g. HB_Control) on the start up of a screen-file?
Win XP SP2, TVC 1.4
Pinkie2
Post by Pinkie2 »
How can I set parameters to the Message I send to Meedio from HBConnector?
Win XP SP2, TVC 1.4
