System Info
- HouseBot Special Member
Dave
It is funny that you said this about the activity as I nearly commented about it yesterday.It does seem a little more active lately. Perhaps sleeping beauty has awoken!?
Ok next question around the same theme.
Does anyone know how you get the info for only one drive? The scripts I have tried give the whole info located within the class.
Regards
PT
PT
That's easy....
If you use the way I did it in the PC Info script it will not even spin up a parked drive. All of the WMI requests will spin up your drive which was unacceptable for me since my data drives park after 30 minutes and I didn't want them to stay alive just for some info.
So for getting info about just one drive, do some filtering. DriveType 2 will filter out all of the harddrives. Then check for the DriveLetter and there you have your "only one drive". I use this specifically for my D-Drive. That drive holds my Meedio TV recordings. I devide the free space on the D-Drive by 1.5 to get the default amount of recording hours left on that drive and I store that in a separate property which is then being displayed on Meedio TV HouseBot Theme Panel.
So take a look at the PC Info code for the example.
Below are two examples about the same thing. The first example is the same as PT uses it and the second is much simpler to read. There is no need to open an object and do all kinds of queries.
strComputer = "."
Set WMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colDisks = WMIService.ExecQuery("Select * from Win32_LogicalDisk")
For each Disk in colDisks
If Disk.DriveType = 3 and Disk.DeviceID = "D:" Then
msgbox Disk.DeviceID & " " & FormatNumber((Disk.FreeSpace / (1024 ^ 3)), 1) & _
" " & FormatNumber((Disk.Size / (1024 ^ 3)), 0) & " " & Disk.Status
Next
Set colDisks = Nothing
Set WMIService = Nothing
For Each Disk In GetObject( "winmgmts:").InstancesOf ("CIM_LogicalDisk")
WScript.Echo "Instance:", Disk.Path_.Relpath
Next
strComputer = "."
Next
Next
Richard Thanks for the reply.
It would seem that you have taken offence to my note. I was only posting a way that I knew how to get some info from windows. I agree that your way would appear much simpler for the most part. Although the two scripts you mention display different information.
I would also agree the benefits of not having to query the drive when it is parked .However the script I posted did not touch on the harddrives, only memory,ip address etc.
This method of querying is used across networks so you can query other machines. I have been able to have all my machines display their properties with this script.
My goal when I asked the original question was to enable some of the functionality to be displayed within a remote. Since asking the question I found the WMI method.
Regards
PT
PT
No offence!
I was also only stating more ways of getting the same results. Sorry if it sounded offensive. I will hide behind the fact that English is not my native language :P
The last I would suggest is that I know anything about vbscript. I am also just in the ripping business when it comes to WMI etc.
I made a slight modification to this script that I thought others might be interested in. I wanted to see uptime in days, hours, minutes instead of hours only. To accomplish this I added the following function to the "PC Info.vbs" script (I got the base code for this from a google search):
I also changed the uptime portion of the main script to look like this:
The two things that changed in the UpTime script are telling DateDiff to convert to minutes instead of hours (important!) and then calling my function to reformat the result.
Function FormattedTime(TimeInMinutes)
' This function takes a parameter that is assumed to be minutes of uptime.
' It converts this number to a string representing days, hours and minutes.
' EDIT HISTORY:
' 25-Jun-2006 Created. Dave Morgan
Dim Days
Dim Hours
Dim Minutes
If TimeInMinutes >= 24 * 60 Then
Days = TimeInMinutes \ (24 * 60)
SELECT CASE Days
CASE 0
CASE 1
FormattedTime = FormattedTime & "1 day, "
CASE ELSE
FormattedTime = FormattedTime & Days & " days, "
END SELECT
TimeInMinutes = TimeInMinutes MOD (24 * 60)
If TimeInMinutes >= 60 Then
Hours = TimeInMinutes \ 60
SELECT CASE Hours
CASE 0
CASE 1
FormattedTime = FormattedTime & "1 hour, "
CASE ELSE
FormattedTime = FormattedTime & Hours & " hours, "
END SELECT
Minutes = TimeInMinutes MOD 60
SELECT CASE Minutes
CASE 0
FormattedTime = FormattedTime & "0 minutes"
CASE 1
FormattedTime = FormattedTime & "1 minute"
CASE ELSE
FormattedTime = FormattedTime & Minutes & " minutes"
END SELECT
End Function
'- UpTime Info -----------------------------------------
For Each OSObject In GetObject ("winmgmts:").InstancesOf ("Win32_OperatingSystem")
Bootup = OSObject.LastBootUpTime
LastBootupTime = PC_DateStringToDate(Bootup)
SystemUptime = DateDiff("n", LastBootUpTime, Now)
Dinfo = Dinfo & vbLF & vbTAB & "PC: " & vbTAB & "Boot Date: " & vbTAB & LastBootupTime & _
vbLF & vbTAB & vbTAB & "PC Up Time: " & vbTAB & FormattedTime(SystemUpTime)
Next
HouseBotStartTime = GetPropertyValue ("PC Info.HouseBot Start Time")
HouseBotUpTime = DateDiff("n", HouseBotStartTime, Now)
Dinfo = Dinfo & vbLF & vbTAB & vbTAB & "HouseBot Up Time: " & vbTAB & FormattedTime(HouseBotUpTime)
I'm logged in ... where is the attachment?
I'm logged in as "HB Guy" yet I cannot see the attachment. Is it posted somewhere else?
PS
Glad to see HouseBot is back under Scott's exclusive stewardship. I tuned out of HouseBot when it became buried under Meedio. I now find it a little troublesome to find scripts, plugins and other user-contributed information because they appear to distributed in Meedio's site and this one. I hope they'll eventually consolidate under one roof.
PS
ScottBot wrote:FYI: Also, it creates a startuP Task now. Notice the upper case P. In HouseBot you can have multiple startup tasks by using different case combinations of the name STARTUP.
idea: maybe for the wishlist. Make a Group in Housebot called startup and let all tasks in that group me started at startup. This Solves: startup, Startup, STartup,.....,STARTUP.
Scott:
Thank you! I look forward to trying it out and learning more about how to extend HouseBot's functionality.
FYI
I'm 5 days into my evaluation period and I'm extremely impressed with your creation. HouseBot's architecture is clean and extensible; it demonstrates 'clarity of thought'. Kudos to you!
FYI
Unable to process dropped file with extension XML
The zip file, posted in this thread, contains a VB Script file and a Configuration Export file in XML format. I tried dragging and dropping the XML file onto Housebot (V2.32 evaluation) and it resulted in the following error message:
Unable to process dropped file with extension [.xml]. This is an unknown extension type.
I tried "File | Import Configuration" but the file dialog box is only interested in opening files with the extension HBX.
What am I doing wrong?
Rename the ZIP file to PC_Info.hbx and put it in the Export directory. Then stop and restart HouseBot and it should get imported.
By the way, there was an error in the enhancement code I posted a while back. I've fixed it but I need to post updated code. I'll try to do it tonight but I just wanted to warn you now (the problem is that the uptime is not accurately reported for uptimes over one day).
