Page 2 of 2
Posted: Tue May 16, 2006 7:01 pm
by Osler
You can just comment that out. On mine, for some reason the page wouldn't download to the variable and vbscript would get all bent out of shape and throw an error when I tried to manipulate an empty string. I don't know a more elegant way to exit the script....anyone....any ideas....I am not a vbscript guru by any stretch.
Posted: Tue May 16, 2006 7:40 pm
by Osler
See if this doesn't fix the problem. I noticed when I looked at it again, it had broken. I have added some code to look specifically for temp, humidity, etc and place it in the correct variable. I also parsed out only the metric readings for you. Visibility has been removed....doesn't appear to always be provided.
'Step 1: Create a Script Device called "CurrentWeather"
'Step 2: Under "Settings", "Property Manager" add the following properties: CWLocation, CWTime, CWTemperature, CWHumidity, CWWindSpeed, CWBarometer, CWVisibility, and CWDewPoint
'====Property Name and Description should be the same
'This is a script to scrape current weather information from the NOAA website for Vasteras, Sweden
Dim sCurrent, oXMLHTTP, sURLCurrent, Parse1, Parse2, WeatherArray(5)
Dim sLocation, sTime
sURLCurrent = "http://weather.noaa.gov/weather/current/ESOW.html"
'Create the xmlhttp object so you can use it to gather data from the webpages
Set oXMLHTTP = CreateObject("microsoft.xmlhttp")
'Get the current data from NOAA
oXMLHTTP.Open "GET", sURLCurrent, True
oXMLHTTP.Send
'Do some error trapping to ensure the server is up and all data was sent
If oXMLHTTP.readyState = 4 Then
     If oXMLHTTP.status = 200 Then
          'Save the html from the site to the appropriate variable
          sCurrent = oXMLHTTP.responseText
     Else
          alert("There was a problem retrieving the current weather data.")
'Destroy the object you created
Set oXMLHTTP = Nothing
'If nothing was downloaded from the site then exit
If sCurrent = "" Then WScript.quit
'Now parse the data out of the file
'Search for the location
Parse1 = InStr(sCurrent, "Current Weather Conditions:<BR>")
Parse1 = Parse1 + 31
Parse2 = InStr(Parse1, sCurrent, "</B>")
sLocation = Trim(Mid(sCurrent, Parse1, Parse2 - Parse1))
SetPropertyValue "CurrentWeather.CWLocation", sLocation
'Search for the update time
Parse1 = InStr(Parse2, sCurrent, "<OPTION SELECTED>")
Parse1 = Parse1 + 17
Parse2 = InStr(Parse1, sCurrent, "<OPTION>")
sTime = Trim(Mid(sCurrent, Parse1, Parse2 - Parse1))
SetPropertyValue "CurrentWeather.CWTime", sTime
For I = 0 to 4
Select Case I
	Case 0
		SearchParameter = "Temperature"
	Case 1
		SearchParameter = "Dew Point"
	Case 2
		SearchParameter = "Relative Humidity"
	Case 3
		SearchParameter = "Pressure"
	Case 4
		SearchParameter = "Wind </FONT>"
End Select
Parse2 = InStr(1, sCurrent, SearchParameter)
Parse1 = InStr(Parse2, sCurrent, "<TD><FONT FACE=" & Chr(34) & "Arial,Helvetica" & Chr(34) & ">")
Parse1 = Parse1 + 33
Parse2 = InStr(Parse1, sCurrent, "</FONT>")
WeatherArray(I) = Replace(Trim(Mid(sCurrent, Parse1, Parse2 - Parse1)), Chr(10), "")
Select Case I
	Case 0
		Parse1 = InStr(WeatherArray(I), "(")
		Parse1 = Parse1 + 1
		Parse2 = InStr(WeatherArray(I), ")")
		WeatherArray(I) = Mid(WeatherArray(I), Parse1, Parse2 - Parse1)
	Case 1
		Parse1 = Parse1 + 1
	Case 3
		Parse1 = Parse1 + 1
	Case 4
		Dim HoldingVariable
		Parse1 = InStr(WeatherArray(I), "at")
		HoldingVariable = Mid(WeatherArray(I), 1, Parse1 - 1)
		Parse1 = Parse1 + 1
		WeatherArray(I) = HoldingVariable & "at " & Mid(WeatherArray(I), Parse1, Parse2 - Parse1)
End Select
Next
SetPropertyValue "CurrentWeather.CWTemperature", WeatherArray(0)
SetPropertyValue "CurrentWeather.CWHumidity", WeatherArray(2)
SetPropertyValue "CurrentWeather.CWWindSpeed", WeatherArray(4)
SetPropertyValue "CurrentWeather.CWBarometer", WeatherArray(3)
SetPropertyValue "CurrentWeather.CWDewPoint", WeatherArray(1)
Posted: Wed May 17, 2006 8:51 am
by wallebalboa
Thanx.
if i comment the "If sCurrent = "" Then WScript.quit " out i get errors with the mid command... probably for empty string...
is it possible to jump to the end of script instead of exit? :oops:
regs AW
Posted: Wed May 17, 2006 11:16 am
by Osler
Yeah, that is my problem as well. Try keeping the WScript.Quit in place. I didn't have the s capitalized and was using .exit instead of .quit. See if it works without commenting it out. Otherwise I may need to add an if/then loop in the server code.
Posted: Wed May 17, 2006 4:00 pm
I thought HouseBot could not handle the WScript object. Why not create a Sub, put everything in the Sub, Call the Sub in the beginning and use the vbscript command 'Exit Sub' when you need to end the script.
Posted: Wed May 17, 2006 4:22 pm
by Osler
hehe....didn't know that about WScript and HB.
That is a prime idea with the subroutine. Much appreciated.
Posted: Thu May 18, 2006 12:37 am
by Osler
Updated after Richards recommendation.
Call(GetWeather)
Private Sub GetWeather()
	oXMLHTTP.Send
     		Else
	If sCurrent = "" Then Exit Sub
	For I = 0 to 4
	Select Case I
   		Case 0
   		Case 1
   		Case 2
   		Case 3
   		Case 4
	End Select
	Select Case I
   		Case 0
      			Parse1 = Parse1 + 1
   		Case 1
      			Parse1 = Parse1 + 1
   		Case 3
      			Parse1 = Parse1 + 1
   		Case 4
      			Dim HoldingVariable
      			Parse1 = Parse1 + 1
	End Select
	Next
End Sub
