I figured I might as well chime in too. Although the split would be nice, I would much prefer additional features. With the batch file I use to restart HB if it dies and Remote Desktop for connectivity I have a very usable alternative to the service option.
Version 3.0 Feature
- HouseBot Special Member
what about leaving the integration and just adding multi-zone capability?
e.g. do not "split" anything. just add the ability to have one instance act as a 'server' to several other slave instances. maybe even build a thin client to act as slaves?
I've seen this work well in situations like this.
Multi-zone control is a HUGE plus!
This is already possible. One instance of HouseBot can "talk" to another instance of HouseBot. And back and forth. I had this set-up for a while and it worked with no problems. I am not talking about the Software Remotes. You just need to by more licenses of the server. Which is cheap when compared to some others...Affini wrote:just add the ability to have one instance act as a 'server' to several other slave instances.
Scott J
aka spike5884
Scott J
aka spike5884
Exactly what I meant to say, but with less words. Having the SWRemotes AND the device replicator which enables you to talk to other instances of HB Servers, is all you need to create a nice multi zone environment.
spike5884 wrote:This is already possible. One instance of HouseBot can "talk" to another instance of HouseBot. And back and forth. I had this set-up for a while and it worked with no problems. I am not talking about the Software Remotes. You just need to by more licenses of the server. Which is cheap when compared to some others...Affini wrote:just add the ability to have one instance act as a 'server' to several other slave instances.
I know I'm late to this party and the votes are cast. But I'm intriqued by the idea of the HB server running as a service. I don't need the UI/server split, as I either use Remote Desktop, or I walk down stairs. But my HB server crashes periodically - never have determined the cause. I'm thinking that if it were running as service this might not happen.
FWIW,
FWIW,
