Page 2 of 3
Re: Grabbing net cam images using vbscript only
Posted: Wed Sep 23, 2009 10:45 am
by raptor_demon
Hi Terry,
The task basically says when timer = 00:00 then run script.
However it is not working when i manually run the script and look at the file on the disk manually.
I have not yet put it into a swremote.
Posted: Wed Sep 23, 2009 1:14 pm
by Osler
I am not sure that you are connecting to the server. The orignal script has no error checking, it assumes you connected and all is well.
Try using the CreateObject(msxml2.xmlhttp) in the new script I posted in place of WinHTTP and see what happens.
Posted: Wed Sep 23, 2009 1:17 pm
by raptor_demon
By server does it mean the Camera?
Posted: Wed Sep 23, 2009 4:31 pm
by Osler
yes
Posted: Wed Sep 23, 2009 8:50 pm
by raptor_demon
no dice, i get the following error:
- error msg
- errorwednesady.jpg (10.55 KiB) Viewed 7968 times
Any ideas?
Terry, here are the tasks i have used:
- task 1
- task1.jpg (12.15 KiB) Viewed 7968 times
- task2.jpg (7.75 KiB) Viewed 7968 times
thanks for your help here guys....
Posted: Wed Sep 23, 2009 8:59 pm
by raptor_demon
ok, weird,
just messing with the code, breking it then putting it back it now works,
I think it is network traffic related....
Option Explicit
Dim URL
Dim File
Dim xmlHTTP
Dim ADOStream
Dim Date1
Date1 = Day(Date)&"-"&Month(Date)&"-"&Year(Date)&"-"&hour(now)&"h"&minute(now)&"m"&second(now)
URL = "http://192.168.2.160/image.jpg"
File = "D:\shares\Photos\Security Cam\Security-"&Date1&".jpg"
Set xmlHTTP = CreateObject("WinHttp.WinHttpRequest.5.1")
Call xmlHTTP.open ("GET", URL, False)
xmlHTTP.send()
Sleep(500)
If xmlHTTP.status = 200 Then
Set ADOStream = CreateObject("ADODB.Stream")
With ADOStream
.Type = 1
.Open()
.Write(xmlHTTP.responseBody)
.SaveToFile File, 2
.Close()
End With
Set ADOStream = Nothing
Else
MsgBox "There was an error."
Set xmlHTTP = Nothing
EDIT: Spoke too soon stopped again.
Posted: Wed Sep 23, 2009 11:45 pm
by Osler
Do you have a firewall on the server?
From the server, run the following script by simply double clicking it. Don't use HouseBot...just run the script:
Option Explicit
On Error Resume Next
MsgBox "Script is starting."
Dim URL
Dim File
Dim xmlHTTP
Dim ADOStream
Dim Date1
Dim WshShell
Set WshShell = WScript.CreateObject("WScript.Shell")
Set xmlHTTP = CreateObject("MSXML2.XMLHTTP")
If Err.Number <> 0 Then
MsgBox "There was a problem creating the objects. Error code: " & Err.Number
MsgBox "Objects created."
xmlHTTP.send()
MsgBox "There was a problem sending the HTTP request. Error code: " & Err.Number
WScript.Sleep 500
MsgBox "Camera server reached successfully."
MsgBox "ADOStream object created."
With ADOStream
.Type = 1
.Open()
.SaveToFile File, 2
.Close()
End With
MsgBox "Image saved."
Else
MsgBox "Camera server returned " & xmlHTTP.status & ". Unable to connect."
SetWshShell = Nothing
Click through the message boxes as the script runs and report back what happens.
Posted: Thu Sep 24, 2009 8:25 am
by roussell
raptor_demon wrote:Hi,
Is the 5 Second Timer Device set to Repeat? If not then that would explain why it only runs once...
Also, you may want to change the first line in the task from
If ('5 second timer.Remaining Time' is Equal '00:00')
to
If ('5 second timer.Running' is Equal 'No')
The remaining time property was a recent addition to the sleep device and while your logic is correct, perhaps HB is missing the 00 transition... Scott can answer that one. I know the "old schoolers" check for a running=no because when the timer hits zero and restarts, the running property momentarily transitions through Yes-No-Yes. It's a shot in the dark, but that's really the only difference between what you're doing and my scripts.
Posted: Thu Sep 24, 2009 9:43 am
by raptor_demon
Hi Terry,
The sleep timer is set to repeat and I am getting images created every 5 seconds they are just identical.
Olser's new code seems to work sometimes iw ill do some more playing tonight....
Posted: Sat Oct 24, 2009 7:56 am
by lostdreamer
Simple problem, simple solutions:
The problem with the images not refreshing is easy..... Cache settings in MSIE.
MSXML2.XMLHTTP uses MSIE to get the URL, with all of MSIE's cache settings.
2 simple options for using the VBS posted by ossler in the beginning of this topic:
1) Open MSIE, go to Extra -> Options -> Temp files and History and set it to "Every time I open a website"
2) Edit the vbs
Call xmlHTTP.Open("GET", URL, False)
xmlHTTP.send()
Becomes:
Call xmlHTTP.Open("POST", URL, False)
xmlHTTP.send "time="+ Now()
Sending the time with the POST data will make sure the result isn't from the cache.
Good luck,
LostDreamer
Posted: Sat Feb 06, 2010 2:04 pm
by raptor_demon
Osler wrote:Do you have a firewall on the server?
Option Explicit
Dim URL
Dim File
Dim xmlHTTP
Dim ADOStream
Dim Date1
Dim WshShell
xmlHTTP.send()
WScript.Sleep 500
With ADOStream
.Type = 1
.Open()
.SaveToFile File, 2
.Close()
End With
Else
Hi Osler,
This script ran without issue when running manually on the desktop however when running the same script in housebot i get an error 500followed by a object created. then a error 13 followed by a camera reached.
LostDreamer,
unfortualty your code produced images that were empty
Posted: Sat Feb 06, 2010 4:05 pm
by Osler
You can't use WSHShell from within HouseBot. Delete all references to it in the script and change "WScript.Sleep" to simply "Sleep". I had to use the shell to get a sleep function outside of HouseBot....but HB has one built in.
Posted: Mon Feb 08, 2010 10:06 am
by raptor_demon
Osler wrote:You can't use WSHShell from within HouseBot. Delete all references to it in the script and change "WScript.Sleep" to simply "Sleep". I had to use the shell to get a sleep function outside of HouseBot....but HB has one built in.
Thanks Osler,
this works great for the Netcam. For some reason tho it does not work well with my album art grab from the squeezebox server.
What did you change in the code?
Posted: Mon Feb 08, 2010 10:51 am
by Osler
I didn't change anything...just made it so the script could run outside of HouseBot.
Post the URL for a album art grab from the squeezebox so I can take a look at it. How are you geting the albumarturi from the squeezebox?
Posted: Mon Feb 08, 2010 11:23 am
by raptor_demon
Hi here is the url:
http://192.168.2.150:9500/music/current ... macaddress of player}
your script works perfectly if i use the url in MSIE and refresh it everytime but if i do not refreshi it the image never changes.....
I have set my MSIE settings to update the page everytime i visit as suggested by lost dreamer.
Any ideas?
