Page 6 of 12
Posted: Mon May 14, 2007 7:00 am
by markd
I'll only ask once a week.
If you want to just post the latest code, I can probably work it out myself.
Markd
Posted: Mon May 14, 2007 10:47 pm
by Osler
Ok...lets see if I can upload this here. It will simply provide an additional message box delineating the error from hbcontrolmod.
Use this executable and let me know what the error message returns as.
Posted: Mon May 14, 2007 10:49 pm
by Osler
BTW, the mutex code posted a few pages back is the latest code if you want to have a look at it.
Posted: Tue May 15, 2007 9:44 am
by markd
Thanks man!
I'll give it a run tonight.
Posted: Tue May 15, 2007 8:42 pm
by markd
Unable to connect to Meedio HouseBot server. Port=5400, IP=, Error=No connection could be made because the target machine actively refused it.
netstat on my server shows
TCP server:5400 server:0 LISTENING
My Action has this argument string-
/P 192.168.1.101 /O 5400 /S * /D Browser1 /C SIB
is my IP address getting lost somehow?
I do not see 5400 on my touchscreen machine wiht a netstat (even when the error messages are up)
I'll try and get into the code too, see if anything presents itself.
Markd
Posted: Tue May 15, 2007 9:07 pm
by markd
Yes, it is. The readme says /P in a couple of places. Maybe in the .hbx too? I'm not going to reload it to check, but that is what is currently in my Argument string of Browser1.
The code is looking for /I. Arguments work much better with /I.
thanks!
Posted: Tue May 15, 2007 10:35 pm
by Osler
Cool!! I will make the changes and get a new version posted in the near future. Thanks for catching this!
Posted: Wed May 16, 2007 6:30 am
by markd
I'm just glad it turned out to be an easy fix. I do wonder how the other users made it work though. . . . ???
I already have it showing google maps traffic on my "front door" panel- I cut a window just big enough to let the map portion show through. You can actually do all the regular navi right there- VERY cool!
Markd
Posted: Wed May 16, 2007 10:17 am
by Osler
Alright, the attached .zip contains the HBBrowser.exe which fixes the command line problems encountered by MarkD. Now the command line variables should conform to what is in the readme file, specifically:
/P [IP Address]
/O [Port Number]
/S [Password] (if there is no password, an asterix should be used in the command line)
/D [Device Name]
/C [Instance Type] (for a single instance browser use SIB, for multi-instance use MIB)
Simply replace the .exe file installed with the orignal download with this one.
Posted: Thu May 17, 2007 11:24 am
by markd
Hi Osler-
The zip only contains a .frm file . . . no exe.
Markd
Posted: Fri May 18, 2007 12:22 pm
by Osler
crap...I'll repost it tonite.
Posted: Fri May 18, 2007 5:35 pm
by markd
No worries. The other way would be to just update the doc files. . . right? It works fine as is.
Posted: Fri May 18, 2007 11:25 pm
by markd
Osler wrote:Has anyone noted a hit in software remote performance when the browser is running? I am running a swremote via rdp (smart display) and remote responsiveness seems a bit hit-or-miss while the browser is running. Anyone else with a similar experience?
I think I am seeing this. . . will experiment more this weekend and try to pin it down.
Posted: Mon May 21, 2007 11:47 pm
by Osler
markd:
When this is happening go and check the server. Click on the swremote tab and see if that particular swremote is connecting/disconnecting roughly once every 2 seconds. This happens with my swremote regardless of whether the browser is running or not. I think this is a known issue that will hopefully be addressed by Scott in future updates.
Posted: Tue May 22, 2007 8:39 am
by markd
I'm not sure what I'm seeing. I'll just list it off and see if anything makes sense.
Last week, I had two incidents where the panel was not getting updated. Re-starting the SWremote did not fix it. Restarting HB did. At that time, I was openning the browser only when requested, then closing it when the panel was closed.
Over the weekend, I was experimenting with leaving the browser open behind the panels, and automatically issuing a reload every 15 minutes. I swear I got to a state (multiple times) where I could not re-start the browser- it would open, start to load, then close. I thought that the Quit property was not acting right- that even though it said False, it was acting like it was True. But then when I went to show my wife the bug, it wouldn't do it!
I left it running like this Sunday night (15 minute refresh). Monday morning I had a "low on virtual memeory" message from windows, and after clicking through that, a notice that browser had crashed with errors, but it was still up. At this point, the browser is very slow when I try to interact with it, and does not seem to be responding to commands from HB. The SW remote is fine though. I let it run overnight again (without restarting anything) and it seems to be in this same state this morning.
I don't see the connect/disconnect thing happening. . . is that in the line where it gives state like sleeping?
Still working on it.. . .
Markd
