After spending a few (more) hours on the application, it all seems to be coming together. However, some of my A/V equipment is consumer based rather than industrial and some discrete codes are getting hard to track down. Since I am a former AMX programmer, I was curious if anyone had tried extracting IR files from Netlinx Studio and/or IREdit for use within housebot.....
Also, completely unrelated, when you add a remote, it asks you for a frequency. When I learn a remote, several frequencies are displayed in the debug window...which should I use? Thanks!
The frequency that HB prompts for is only relevant for the Ocelot Hardware Interface. If you're not using an Ocelot, you can enter any value. It's there for IR code compatability across hardware interfaces (not that anyone really uses the same code over different interfaces).
