File/New/Device only presents 'Requires Hardware Interface'
Posted: Tue Nov 25, 2003 10:29 pm
by Circe640
I just installed HouseBot on the second machine - the HTPC. I am trying to setup the Winanp device so I can replicate between servers. When I go to File/New/Device --- the form come up but the dropdown box only has the option 'Requires Hardware Interface' There is no option for a software device at all. But on my HCPC it comes up with all drop down options. The only difference is that on the HCPC I installed 1.61 over the existing version whereas on the HTPC it is a brand new install --- What am I missing or is this something that is related to 1.61 on a new install?
Posted: Sun Nov 30, 2003 8:25 pm
I've tried to reproduce this on two machines, but can't seem to replicate the problem.
You might want to reinstall again on the HTPC and see if that helps.
Maybe it's something about that specific machine. What hardware/os is it running?
Posted: Fri Dec 05, 2003 10:24 am
I just fixed a UI problem with the combo box in this dialog. It was sized such that you could only see a single item in the drop-down list.
Could this be what you are seeing?
