Global Cache IR
jasonb1
Global Cache IR
Post by jasonb1 »
Is this a bug?
I have used the "Load Pronto XML" to create IR data for a remote and that seems to have worked correctly. However, it looks like I can't load that data quickly or at all into the Global Cache setup.
I can only figure out how to create new remote codes from the Global Cache IR setup screen, not load in or point at existing IR codes in the remote control library.
If I have to enter them all in manually, that will surely take a while...
- Jason
As you've noticed, the GC-100 plugin is a bit out of date. I'll update the IR configuration and let you check it out.
