Read Only Properties
Is there the ability to have read only properties for devices, so that the user wouldn't be able to even try to change the value from the GUI.
I know the device could just return false when something tried to change the property but it would be nice to have the GUI disallow and try to change the value.
Eric
Eric
- Advanced Member
- Contact:
Set them up in the GUI so they are Property Labels
If you set them up in the GUI as property label controls, the user cannot change them~!!! IF you use a property edit controls, then they can change them.
No, the standard Property Values do not support read-only. In my grand design, you could specify whether a Property value was input, output, or both (you can see this in the register property function). The idea was that you could restrict the UI based on the type of property and it might also help when creating Task conditions and even Theme control assignments.
But I never implemented it.
One thing you could do for your thermostat control, is register a Property Button and then show your own UI for setting up the Device. This would allow you to display a graphical representation of the time/temperature schedule (if you really want to get into it) and would allow you to make properties read-only if you would like. Unfortunately, if you keep your own settings, the values won't be accessible from Tasks or Theme controls.
Eric,
How bad do you need a read-only property, and would you want it to always be read-only or would it sometimes be read/write?
It might be easy enough to simply lock the Property Control for that value and use the 'eIOType' setting to indicate its read-only state. You wouldn't be able to change to to read/write later though.
Thanks for the reply. I think I will use the standard property interface for the thermostat control (I don't think I will have any read only properties for that device anyway). I was mainly asking out of curiosity and for future reference if I end up making the LynX-10 PLC plug-in. That device has some interesting info that you can get from it like how many X-10 collisions/retries, etc... I wanted to be able to present it to the GUI as a property but as read only.
Eric
Eric
- Advanced Member
- Contact:
Here's a little cheat around it
In the pluging you can receive property change notifications if a property in your plugin is changed in housebot. It is the way your plugin reacts to HouseBot. If you receive a change on a property you consider Read-Only simply react and change it back to the value in the pluging itself.
I figured that I could just let the device chage it back once it got the notification. That what the system time device seems to do with the weekday property but to me it is cleaner if the GUI keeps you from changing read only properties.
Sorry for dragging this thread out but this is what I do all day for a job and I'm kinda picky about the GUI. That is one reason I'm trying to make the switch from HomeSeer.
Eric
Eric
No, no... now you've got me engaged. I've already made the changes to the server to handle this.
Next I'm going to update all of the Device Properties to correctly flag their read-only devices. Unfortunately it will only take effect for new Devices created, since the ioFlag is stored in the DB when the Device is first created.
I'll have to update the help as well, but I like the read-only effect. I've never really liked the fact that you could change these. It added to the confusion, which is what 2.0 is supposed to be solving. The System Time Device that you mentioned is the biggest and most visible example of where it doesn't make sense to change the values, but it seems as though you can.
Yes. It's only read-only from the 'user' side. The Property Control won't even give you the opportunity to change it, but it can be changed by the Device. For example, I've changed the System Time Device to have all read-only properties. They continue to update as before, but the UI no longer allows you to modify them (a small lock is shown next to the read-only properties).ericvic wrote:Would a device still be able to set the value for it's own read only properties?
When registering Device properties you can set it. Look at the pHB_RegisterDeviceProperty() and pHB_RegisterDevicePropertyUsingWizard() callback functions in DeviceAPI.h and you will see it as an argument. If you set it to ioInputOnly, it will be read-only. It's not called 'read-only' because my original model had the idea of a graphical method of connecting properties, so the inputs would go to the outputs. It's the same idea, just represented a bit differently than you might think. Note that this is for the Device SDK only. The Hardware SDK is not consistent with the way it handle Properties, since they are really a different kind of property.ericvic wrote:Also where do you set the 'eIOType'? I looked through a few of tghe classes and didn't see anything.
This may not actually help you at all if you are thinking of showing the properties in the Hardware Property view. If you have the hardware propagate the values along to all its Devices (through subscription notifications), you can show the data from the interface in your Devices.
It's probably not documented clearly anywhere
The system comes with a slew of stock Properties you can use when creating your own Device. You can see these from the Property Manager (Settings/Property Manager... from the main menu). Devices can share the same Property, but can only have a maximum one of each property (as defined by its Name).
So generally, you should look through the list of Properties and see if you can find one that has a type like the type you need and a name that somewhat expresses the purpose of the Property. If you find stock properties, you won't need to create them yourself, which saves a step. If you don't find a stock property that you want to use, you can create your own dynamically with pHB_CreateDeviceProperty().
When doing this, you only want to create the Property the first time, so you will need code in your ::RegisterProperties method that goes something like below that first tries to register the property. If the registration fails, it can assume that it is because the property doesn't exist. It can then create the property and try to register it again.
So the bottom line is to try an use an existing Property if you can with pHB_RegisterDeviceProperty (or pHB_RegisterDevicePropertyUsingWizard if you want the Wizard to prompt for the value during Device creating).
if (!m_CallBackInfo.pHB_RegisterDevicePropertyUsingWizard( m_CallBackInfo.m_hModuleHandle, nDeviceNumber, "New Property", ...))
if (!m_CallBackInfo.pHB_CreateDeviceProperty( "New Property", ... ))
return( FALSE );
if (!m_CallBackInfo.pHB_RegisterDevicePropertyUsingWizard( m_CallBackInfo.m_hModuleHandle, nDeviceNumber, "New Property", ... ))
return( FALSE );
return( TRUE );
Thanks for the info.
It is probably staring me in the face but how to I add what the valid values are for a property? i.e. I'm going to have a fan property that should have 'on' and 'auto'.
Also I am going to need a read-only property for the thermostat for the current temp so I'll get beta 4 tonight and try it out.
Eric
Eric
