Positioning text on controls
yaccri
Post by yaccri »
All control buttons' text is automatically left justified.
It would be of value to have a property that would define the position of the text on a button: Left, Center or Right.
In the language that I use (Hebrew), we write from right to left, and text that is left justified looks bad.
A workaround may be adding spaces, so this is not critical. However, it involves more work on the interface.
Yoram
Yoram,
There are options on the "Position" tab of the button property window that allow you to center the text or specify the exact starting X or Y coords (text offsets).
Will the current "Position" options work for you, or do you need a 'right justify' option?
yaccri
Post by yaccri »
The 'position-offset' property is a nice option. I didn't notice it earlier.
It should be enough.
yoram.
