If I change the IP address of the HB server how can I change the client configuration to point to the new address without waiting for a timeout?
Actually after two unsuccessful attempts the SW remote did start again in the configuration mode but I didn't seem to find a way to get there directly.
Client Configuration
You can bring up the Software Remote configuration screen by using the "/config Set" command line option.
Generally, the Sofware Remote will automatically bring up the screen if it detects that the prior connection was unsuccessful (it assumes that the connection may have been unsuccessful due to a configuration problem).
