Cheap Thermostat for controlling the central Heating ??
Posted: Sat Sep 11, 2004 6:02 am
Hello All,
I;m searching a few weekends in a row for a thermostat to control the two wired central heating in my home. I allready have purchased marmitek pc control en light units. I want the heating to be controlled by the housebot with X10 commands.
The best i could find is a "RCS Tx15b" for 249 dollars. I don't even know if it is available for purchase in the Netherlands. I cannot believe this is the only solution.
It only has to set a temperature, the thermosstat will do the rest. Day programming etc will all be done by thehousebot.
Is there also somebody who uses electronic valves to enable heaters in a per room base? This is a site step to my main problem, i cann;t find a good thermosstat to use with housebot.
Conclusion:
Question:
Which thermostat works fine with housebot ? X10 is preferable but not a must.
Best regards
Tukker Tom from the Netherlands
Conclusion:
Question:
Best regards
