I am having trouble sgetting HouseBot to show me the panles on the computers screen ?
Is this not possible ?
How do I achieve this ?
Rgds,
Michael Lindgaard
http://www.lintronic.dk
Can't open Thems/Panel on PC screen ?
Rgds,
Michael Lindgaard
Michael Lindgaard
Michael,
I assume that you have already created some Panels using the Theme Editor, or are trying to see the Sample Theme.
Themes are executed using the Software Remote application (SWRemote.exe). If you just want to see the Theme running on the HouseBot server machine, click on the Software Remotes item in the main tree view and select the Local Remote item. Set the Theme you want to see as the Default Theme. Then select Local Software Remote from the HouseBot program group (from the Windows Start menu). To run the Theme on other machines, you will need to copy the appropriate SWRemote.exe file to the machine. There are different versions of the Software Remote for various PC platforms.
