Dial Enhancement - Max Min bound to properties
Would it be possible to enhance the Dial control so that the Max and Min values are bound to Device properties?
Anythings possible now that Meedio has the wheel.
Normally this wouldn't be needed though, since the Dial is bound to a particular Property and Properties generally have set limits.
An alternative would be to use a script to calculate the Dial position based on your min/max/value settings and set another property that is used by the Dial. This would be doing the same thing as the Dial logic if it were implemented as you suggested.
I kinda expected I would have do something like that.
I modelled a Thermostat using a Null Device, it has Proprties for Max & Min temp, current Temp and current State (Heating/Cooling). The Max & Min values are used to detemine when the state changes from Cooling to Heating & vice versa.
I have created a Theme Panel will Dials for the Max & Min values and a Gauge to show the current Temp. I wanted the set the Min & Max values of the gauge to be the same as the Thermostat Min/Max values rather than some arbitary 0 - 100 degrees C. i.e. the Gauge is relative to the comfort settings rather than absolute. I gues I'll have to calculate the gauge value as a percentage of the Min & Max value rather than use the absolute temp reading.
