Minor issue when adding actions to a task
Posted: Mon Oct 25, 2004 1:11 am
Hi Scott,
I found a minor issue when adding actions to an existing task. This happens for me every time. Here are the steps:
- click on an existing task
- click on the "Add Item..." button
- choose Add Action
- add any action
- click OK
When I do this I get an "Else" line followed by the chosen action. The only way I've found to make this work correctly is to click on one of the existing action lines first before clicking "Add Item...". I've also found that even when you are first adding a task if you move focus somewhere else and then click "Add Item..." again the same problem occurs.
- choose Add Action
- add any action
- click OK
