Clear the contents of a list control?
Plain and simple - is there any way to clear the contents of a list control? I want to be able to start with a blank slate every time I open a panel that contains a list control. I tried doing this
SetPropertyValue "DVD List.DVD Titles", ""
in a script and then executing that script as part of the Enter List for the panel but nothing happened.
Re: Clear the contents of a list control?
Try this:
SetPropertyValue "DVD List.DVD Titles", Chr( 10 )
That did the trick. It's funny - I actually thought of doing this last night as I was going to sleep (I just can't seem to stop thinking about HouseBot :wink: ).
I think this is a good example of where a "multi command" or "macro" button type would be useful. I open the panel containing the list control using a panel change button. In the panel Enter List I have my script that is run to clear the list box and some associated values. The issue is that I briefly see the list and values right after the panel opens before the script is run.
Ideally I would clear these values *before* opening the panel but I don't know how to accomplish that. I would use a script or task but I can't open the panel on only a specified software remote. If I had a "multi command" button I could run the script to clear the values and then change panels. Can you think of any other way to accomplish this?
How about clearing the lists when you leave the Panel? Then they will be empty when you return.
Gee - that sounds like a great idea! I wonder why I didn't think of that :-)
