remote client looses connection after long idle time
Posted: Wed Dec 01, 2004 6:31 pm
by Paul Forgey
If the remote client runs long enough, the connection seems to time out. The buttons don't change any property values and controls showing property values aren't updated. Telling the client to reload the theme restores functionality until the next time out.
This seems to happen if I leave it for more than 12 hours or so, indicating this could be the system's TCP timeout. Is SO_KEEPALIVE set? This isn't a LAN issue because my remote client is connected via loopback (127.0.0.1).
Re: remote client looses connection after long idle time
Posted: Wed Dec 01, 2004 8:30 pm
Paul Forgey wrote:...Is SO_KEEPALIVE set?
No. I'll do some testing with it set to see if there's any difference.
Posted: Thu Dec 02, 2004 10:16 am
Paul,
When this happens, do you still see the Software Remote listed in the Active Software Remotes list on the HouseBot server?
Posted: Thu Dec 02, 2004 4:59 pm
by Paul Forgey
ScottBot wrote:Paul,
Apparently it takes longer than 12 hours for this to happen (I went home and watched TV after my last posting), so I'll get back to you in the next 24 hours. In addition, I'll leave another instance of it running on another machine to see if there's any difference in behavior.
Posted: Fri Jan 14, 2005 3:02 am
by Paul Forgey
finally happened again. I don't think it's a timing issue- took only 40 minutes or so this time. According to House Bot the state was still ''in session".
Posted: Fri Jan 14, 2005 12:12 pm
I've never seen this myself, but it may be a result of the way some drivers are handling ... something... maybe powersave.
The next release will have the clients connected with the SO_KEEPALIVE flag, so hopefully that will help.
