small plug-in interface questions
Posted: Wed Dec 08, 2004 4:22 am
While writing my HouseBot plug-ins, I decided to expand the plug-in support classes to be a bit more comprehensive and make writing future plug-ins easier.
In doing so, I found a few potential const violations, and I want to be sure I can depend on these particular pointers being returned to HouseBot to be honored as const (and if not, why). Really, I'm not trying to trash on the author of this code, but the pointers as they stand are interfering with desigining const correct classes being built on top of the interface.
in Devices/Common/DeviceAPI.h:
in struct DeviceInfo:
char *m_szDeviceInfo
char *m_szInterfaceSignatures
char *m_szModuleWizardDescription
char *m_szWizardFinalText
Shouldn't all of these be const? HouseBot isn't going to modify the strings returned via HBGetDeviceInfo is it?
in struct DeviceCallBackInfo:
HARDWARE_RC (*pHB_SendInterfacePackToInterface)(DEVICE_HANDLE, InterfaceArgumentPack *);
Is there any sane reason for the destination interface to modify the contents of the InterfaceArgumentPack?
in struct ModuleInfo:
char *m_szModuleVersion
char *m_szModuleName
same comments from DeviceInfo.
HBDeviceModuleInit( DeviceCallBackInfo*, ModuleInfo **ppModuleInfo );
shouldn't ModuleInfo ** be const ModuleInfo **? That's a pointer to a volatile pointer to const data, so it still works as an out parameter. DeviceCallBackInfo * should also be const since you do not intend for plug-ins to mess with this data.
HBGetDeviceInfo( int nDeviceNumber, DeviceInfo **ppDeviceInfo );
same comments from HBDeviceModuleInit for ppDeviceInfo.
HBDeviceSubscribeNotification( DEVICE_HANDLE, LPCTSTR szListName, LPCTSTR szFilter, CDataPack *pDataPack )
Same comments as the InterfaceArgumentPack from pHB_SendInterfacePackToInterface.
Also with the TCHAR pointers.. I see no follow-through using them as such in the example code and supporing classes from Common. Are there plans in the future to support unicode? I would probably use a more complete strategy for doing so, such as using char * and passing wchar_t * to entry points of a new name. TCHAR's are messy and really shouldn't be used on code that will never need to compile on non-unicode capable versions of windows. That's just my opinion.
in Interfaces/Common/HardwareAPI.h:
void (*pHB_NotifySubscribedDevices)( LPCTSTR szListName, LPCTSTR szFilter, CDataPack *);
BOOL (*pHB_RemoveIRCode)( IRCode* pCode );
Also a suggestion: If HouseBot allowed a user pointer to be stashed in a DEVICE_HANDLE, that might be more efficient than requiring the plug-in to store a map of DEVICE_HANDLE's to CDevice* instances.
