Hello i have found two annoying display update problems when editing themes.
1. new theme - change the name of first panel - right klick outside panel properties to add new panel (no enter/cr) - the tab for the new panel will get the first panels name. this stays until saved and refresh (go to another theme and back) However its only in the tab display so if you ignore the tab name all data will be right (its correct in panel properties window)... however its easy to make misstakes with the wrong name on the tab...
2. Multi state button - states - add state- add a new state with if value is 1 - now something strange happens, it jumps back to default state and no change if value. sometimes it looks like the tab broblem in previous error, mismatch in state selection and state display..
just trying to get housebot even better
kind regs
Graphic glitch when editing themes
Great answer -- but adding some more graphic refresh issues
Great answer . looking fwd to that..
here some more :roll:
I have made a tree structure of device groups:
devices>IOboard>inputs>port>PA0 (the pin on the io board connected to physical device)
Its good that the device list views the state of the default property and reflects changes live. but this only works when i selects the top level ( devices) or the port level. ( not IOboard level and input level) .
related to this might be the update problem of the "led" showing active modes. this updates everytime i select the modes folder but not "live"
a grouping function of modes could also be a great enhancement
thanx for a great SW, and keep up the good work.
Re: Great answer -- but adding some more graphic refresh iss
Thanks. I'll look into this.wallebalboa wrote:Its good that the device list views the state of the default property and reflects changes live. but this only works when i selects the top level ( devices) or the port level. ( not IOboard level and input level) .
I'll look at this too.related to this might be the update problem of the "led" showing active modes. this updates everytime i select the modes folder but not "live"
I've never really had that many modes myself. I guess that's why I never though to group them. I'll add this to the list, but can't say when it would be addressed.a grouping function of modes could also be a great enhancement
