HouseBot server crash
I've had my HouseBot server process crash a couple of times recently. Both times seem to be for the same reason and caused by the same device. I've also had problems with the device that caused the crash. It *was* working fine and I can't remember changing anything.
This device is something that really only needs to run once a day but since the time it runs needs to be dynamic I've created properties with the hour and minute values. I have a task that runs once a minute which executes the script. The script runs every minute and aborts if the time is not right. I can email the script if you like.
I've also found twice (probably related to the crash) where the script device state was running and it had been like that for hours. When I tried to change the state to stopped I got an error like this (I was going to give the exact text but the HouseBot server crashed while I was at work so I lost the error log from the last session): "Script device is not running running. Unable to change State property". Note: the fact that running is listed twice above is *not* a typo on my part - this is what the error message said.
Is there any kind of tracing I can turn on to help debug this?
Here is the dump file. Any clues?
====== Begin Dump - Wednesday, January 05, 2005 06:43:00 ======
Server Version = 2.21 (ß 4)
Thread Type = Device Thread [Script Device] - [Bedroom Clock Radio]
Thread ID = F88
Fault address: 00000030 00:00000000
Registers:
EAX:08393E60
EBX:00000000
ECX:1183B300
EDX:1183E06C
ESI:08057540
EDI:1182F2B0
CS:EIP:001B:00000030
SS:ESP:0023:0E61FE8C EBP:1181F990
Flags:00010206
Call stack:
Address Frame
00000030 0E61FE88 0000:00000000
004DE847 1181F990 CxImage::`copy constructor closure'+DCDD7
08057540 00581910 0000:00000000
004DF6F0 004DF660 CxImage::`copy constructor closure'+DDC80
====== End Dump ======
Unfortunately, I can't tell much from the dump and there's not really much that tracing will help in this case. Please send the script to me ([email protected]) and I'll see if I can duplicate it.
