Skins/Themes
AndyA
Skins/Themes
Post by AndyA »
I know this has been asked before, but does anyone have any good themes for housebot?
Or does anyone know if you can use a third party software solution such as MainLobby? I have seen that HomeSeer can be used with MainLobby, could Housebot be used this way?
Andy.
Unfortunately, until HouseBot is setup in the MAID system, there isn't really any way for HouseBot users to share their skins.
If you haven't seen this post, it has a few skins.
AndyA
Post by AndyA »
Thanks for the reply Scott,
I am fairly new to Housebot, but learning fast!
I have a few questions for you, if you do not mind?
1 Can you input CCTV pictures from cameras ie, front door etc?
2 Is there a way of monitoring incoming phone calls and producing a caller ID to be displayed on screen?
3 What does your system control? just to give me an idea of how far I can go!!
Regards, Andy.
AndyA wrote:1 Can you input CCTV pictures from cameras ie, front door etc?
You can't insert a live feed into a Theme, although you can have the Theme wrap itself around an existing stream viewer application. You can also use 'dynamic image' controls in the Theme. The dynamic images can be in JPG, PNG, or BMP format and can be used to display anything you like. When you update the dynamic image property in HouseBot, it will send the new image to the Software Remote, so you can possible do it this way.
Yes. You can use the Modem Phone Status Hardware Interface and Device to do this. You will, of course, need a modem attached to the HouseBot computer that can receive the caller ID info. I do this and even have the caller ID info sent as an SMS message to my cell phone if I'm not home.
I control quite a bit, but my system isn't really all that elaborate. I control my media room via IR, RS232, relays, etc. Also various X10 and Z-Wave devices throughout the house. More interesting for HouseBot is how it is controlled. I've got many many Tasks that automate lights, Caller ID info, Meedio room components, etc. Once you dig into it you'll see that although it has its limits, you can do pretty much all of the common automation tasks.
Regards, Andy.[/quote]
