I would like to control more than the 3 zones that USB-UIRT supports. I like this product a lot, but it is limited to 3 zones, and for some applications this is not enough.
If I got it right, the GC-100-12 controls 6 zones.
Can HB control more than one GC100 unit, to allow more than 6 zones?
Also the GC-100 is a bit pricy. Is there a cheaper way to control multiple zones (the more the better)?
IR zones
Re: IR zones
Although I've never tested it, HouseBot should be able to control as many GC-100's as you need.yaccri wrote:If I got it right, the GC-100-12 controls 6 zones.
The GC-100-12 comes stock with 2 IR modules (each module has three ports). I have this unit and it definitely supports six IR ports.
The cool thing about the GC-100's is that they are modular. I'm not sure if they are currently sold this way, but you can customize the configuration to suite your needs. The GC-100-06 has one extra expansion module that you could add another three IR ports with. You could even replace the existing RS232 module with three IR ports. The GC-100-12 has two empty modules so you could add another six to the six it already has. I'm not sure how you order the additional modules.
HouseBot detects the modules that are configured, so the current plugin should work fine with any module configuration.
