I got a Question. I have about 15 lamp modules in my house which are controllable by X10 but also by normal switches. When the X10 state is on and I turn off the light by a normal switch the system does not know the state changed to Off. This is not really a problem if it sends a On or Off state via X10. But it seems to mee that is is more a toggle then a state it send. Is this correct and is there a way to change this ?
The problem lies for example in a task: "All Lights Out" which ofcourse should turn off all the lights. This isn't the case, it only turns off the light which has a X10 stat of On but it turns on the lamps which have a X10 state of off. Not verry usable
Thanks in advance
