Winamp Ids
Posted: Sat Aug 27, 2005 3:38 pm
Scottbot
I am looking at your winamp sample plugin.In the config file does the id in the list correspond to a Winamp id (ie command)
<Property Com="" Default="0" Desc="EQ 600 Hz Level" Dynamic="No" ID="110" IO="0" Name="EQ 600 Hz Level" PValue=""
Persist="Yes" Prompt="0" SVC="No" Type="0" Value="2.525"/>
If so can you add other commands for winamp ids or are there any limitations in the Dll file?
Cheers PT
Cheers PT
