You can currently set a Command to Send from HB to Essential so sending Pause will pause any playing media within Essentials.
It it possible to reverse this feature (in the future) so that a Device Status within HB will be changed Depending on what Essentials Musci/DVD/Video player is currently at ie play, pause , FFW, REW, REC. So that if you Pause something in Essentials the HB Command Received Device Status will change to match that.???
Command Received from Essentials
