I actually did find that thread, I imported it into housebot, but I don't actually have the TV Listing Device that is supposed to be built into HouseBot. Any ideas?
Looks like I should just be able to install a new TV Listing device, but I couldn't find it.
The TV Listing Device is in version 2.22 also. Select File/New/Device. Then select the 'No Hardware Required' radio button. You should see the "TV Listing Device" in the selection list.
If it doesn't show up, re-run the setup and make sure the plugin was selected when installing.
