I use a Marmitek X10 CM11 interface for my home automation. Everything worked fine before I went on vacation. When I came back, I didn't work anymore.
Let me describe what equipment I have.
My PC has Windows XP. I used to run SP2 but after the CM11 failed I reinstalled and now use SP1
I use a serial interface to my CM11. I tried both COM1 and COM2 ... no difference
I changed the batteries a couple of times... no difference
When I try to change the state on one of my lamps or appliances, housebot gives me the following error:
Error: Due to an error, Device [Lamp naast TV] Property [Power State] DID NOT change
AS said: Everything worked fine until.... until what??? I don't know!!! I haven't changed ANYTHING. Well, I started making changes to my configuration AFTER things stopped working but I'm lost now. I'm thinking my CM11 is broken. Does anyone have a clue???
Thanx,
Daan
